Bug report
Describe the bug
Here is a clear and concise description of what the problem is:
Move last nightly build to eMMC via script. And with 4k resolution I got huge image tearing. If set resolution to 1080p it’s gone. I try hard reset, same problem. I rolled to stable build and problem is gone.
With CoreELEc on SDCard no this bug.
To Reproduce
Steps to reproduce the behaviour:
- Use eMMC
- Set resolution to 4k
- Use interface
Debuglog
The debuglog can be found here:
Screenshots / Video
Here is a video or screenshots to help explain the problem:
CoreELEC version and device
CoreELEC version:
Device: Odroid N2
Device Tree:
Other information, sample media (if appropriate)
Here is some additional information or sample media that might help:
