I’ve been using my two ODroid N2 units as NextPVR clients for several months now with minimal issues, but just found something I’m trying to resolve. I’m using one N2 in a new room with an older computer monitor that only has one HDMI port. The monitor is hooked up via HDMI to a PC for use during the day, but I have been connecting it to the N2 for use in the evening. When I plug in the N2 HDMI cable in the evening the N2 in unresponsive, LEDs are off, nothing I can do with it except cycle power, then it works fine.
The power saving functions are all disabled. And if I unplug the HDMI cable from the N2, the N2 LEDs stay on. If I plug the HDMI back in within a few minutes it still works fine with the N2.
So it seems like there is likely some kind of timeout/shutdown on the N2 if it loses HDMI comm? I’m wondering if this is a known issue/option and is there a way to fix it/disable it?
I unplugged it now and will try to keep an eye on it to see when the LEDs go out, if that is meaningful info.
Thanks,
-Brad
