Just installed both Arctic Zephyr 2 and Arctic Horizon on my C4, both seem to perform fine. I’m a bit old school and still sue Confluence so may not be the best judge of skin performance.
What about wifi/network/usb speed in C4 vs N2? Is it the same, or N2 is better?
It’s not just about two more cores?
Don’t know about USB, but both are fine in ethernet transfer speeds.
Neither has wifi, you need a USB adapter.
Both the C4 and the N2 use the same Realtek ethernet chipset, and both use a USB hub to provide the USB ports (albeit different chipsets). I can’t see how performance would differ between the two.
Main difference between the C4 and N2 are the form factor, and the performance of the SoC. The N2 has a faster CPU and GPU.
Yeah it great. Prefer zepher myself.
Just got my C4 today. Really enjoying it, GUI runs a smooth 60fps and addons such as artwork beef run so much faster than the C2. Forcing the GUI to 4k cuts the frame rate, feels about 20fps, but not a huge deal. 4K HDR works out of the box, will be checking out Netflix later. Definitely a huge upgrade over the C2.
