wow, thanks @boot2k3
CoreELEC:~ # dmesg | grep reset
[ 0.574203@3] meson6-dwmac ff3f0000.ethernet: no reset control found
[ 42.952146@0] usb 1-1.3.4: reset high-speed USB device number 9 using xhci-hcd
[ 46.367818@5] h264_reset_qos_mgr
[ 46.370625@3] h264_reset_userdata_fifo: bInit: 1, ri: 0, wi: 0
[ 46.840201@5] fb: outputmode changed to 1080p24hz, reset osd0, (0, 0, 1919, 1079) -> (0, 0, 1919, 1079)
[ 331.112130@3] usb 1-1.3.4: reset high-speed USB device number 9 using xhci-hcd
[ 333.884366@3] h264_reset_qos_mgr
[ 333.895721@4] h264_reset_userdata_fifo: bInit: 1, ri: 0, wi: 0
[ 333.969639@5] h264_reset_qos_mgr
[ 333.971671@4] h264_reset_userdata_fifo: bInit: 1, ri: 0, wi: 0
[ 338.456193@2] fb: outputmode changed to 1080p60hz, reset osd0, (0, 0, 1919, 1079) -> (0, 0, 1919, 1079)
[ 868.250275@4] h264_reset_qos_mgr
[ 868.254686@1] h264_reset_userdata_fifo: bInit: 1, ri: 0, wi: 0
[ 892.966332@0] h264_reset_qos_mgr
[ 892.976385@1] h264_reset_userdata_fifo: bInit: 1, ri: 0, wi: 0
[ 1347.144349@3] usb 1-1.3.4: reset high-speed USB device number 10 using xhci-hcd
CoreELEC:~ #
will try to find a workaround in the odroid forum.
[ 844.136109@3] usb 1-1.1.3: reset high-speed USB device number 6 using xhci-hcd
[ 844.516203@1] asoc-aml-card auge_sound: S/PDIF Playback disable
[ 844.516262@1] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[ 844.516271@1] aml_spdif_fifo_ctrl, bit depth:16, frddr type:1, toddr:type:1
CoreELEC:~ # lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 2: Dev 3, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 6, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 1: Dev 5, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 4: Dev 7, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 3: Dev 4, If 0, Class=Vendor Specific Class, Driver=8812au, 480M
