I use ugoos am6b plus with firmware dual boot (android9+coreelec in firmware) v.0.4.1 when boot to coreelec and auto update to 9.2.7 everything not sound. Can fix ? But if not update coreelec 9.2.2 everything is ok.
Ugoos dual boot firmware is not supported. Install Android and boot CoreELEC from uSD/USB.
There won’t be any fixes for Leia at this point, if 9.2.2 works for you just stick with that or try the latest matrix version.
They locked the bootloader so dual-boot is the only option now for the OP. In reality all it does is creates a separate partition for CoreELEC, I’ve been using it for over a year with no problems. But I understand why you don’t support it.
