Sometimes when I press play, it will loading indefinitely. Once it is in that state, nothing will ever be play. Even when I change to play other, nothing played.
I have a similar problem with switching TV channels. Sometimes when I watch one channel for a long time and switch to another, the player stops.
21:20:20.803 T:2680890224 INFO: AddOnLog: DVBViewer Client: Timeshift: Started
21:20:20.803 T:2680890224 DEBUG: CInputStreamPVRChannel - OpenPVRStream - opened channel stream pvr://channels/tv/Wszystkie/pvr.dvbviewer_332.pvr
21:20:20.803 T:2680890224 NOTICE: Creating Demuxer
21:20:20.803 T:3710800752 DEBUG: AddOnLog: DVBViewer Client: Timeshift: Thread started
21:20:20.804 T:3710800752 DEBUG: CurlFile::Open(0xc89ef190) http://192.168.1.4:8089/upnp/channelstream/2342468258105658412.ts
21:20:20.814 T:3710800752 ERROR: CCurlFile::Open failed with code 404 for http://192.168.1.4:8089/upnp/channelstream/2342468258105658412.ts:
21:20:20.884 T:4093638240 DEBUG: CPlayerGUIInfo::InitCurrentItem(pvr://channels/tv/Wszystkie/pvr.dvbviewer_332.pvr)
21:20:20.884 T:4093625200 DEBUG: CAnnouncementManager - Announcement: OnChanged from xbmc
21:20:20.884 T:4093625200 DEBUG: GOT ANNOUNCEMENT, type: 1024, from xbmc, message OnChanged
21:20:20.914 T:3903832944 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Info.OnChanged - data: null
21:20:20.915 T:3895440240 DEBUG: Skin Helper Widgets --> Kodi_Monitor: sender xbmc - method: Info.OnChanged - data: null
21:20:20.919 T:4093638240 DEBUG: CPlayerGUIInfo::InitCurrentItem(pvr://channels/tv/Wszystkie/pvr.dvbviewer_332.pvr)
21:20:20.919 T:4093625200 DEBUG: CAnnouncementManager - Announcement: OnChanged from xbmc
21:20:20.919 T:4093625200 DEBUG: GOT ANNOUNCEMENT, type: 1024, from xbmc, message OnChanged
21:20:20.919 T:4093625200 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
21:20:20.919 T:4093625200 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
21:20:20.984 T:4093638240 DEBUG: CDirectoryProvider[pvr://channels/tv/*?view=lastplayed]: refreshing..
21:20:20.986 T:2854318960 DEBUG: CPVRDirectory::GetDirectory(pvr://channels/tv/*?view=lastplayed)
21:20:21.015 T:3903832944 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Info.OnChanged - data: null
21:20:21.017 T:3903832944 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnPlay - data: {"item":{"channeltype":"tv","id":39,"title":"TVP 2 HD (pol)","type":"channel"},"player":{"playerid":1,"speed":1}}
21:20:21.019 T:3895440240 DEBUG: Skin Helper Widgets --> Kodi_Monitor: sender xbmc - method: Info.OnChanged - data: null
21:20:21.020 T:3895440240 DEBUG: Skin Helper Widgets --> Kodi_Monitor: sender xbmc - method: Player.OnPlay - data: {"item":{"channeltype":"tv","id":39,"title":"TVP 2 HD (pol)","type":"channel"},"player":{"playerid":1,"speed":1}}
21:20:21.265 T:2680890224 ERROR: Open - error probing input format, pvr://channels/tv/Wszystkie/pvr.dvbviewer_332.pvr
21:20:21.273 T:2680890224 DEBUG: ffmpeg[9FCB2370]: Probing mp3 score:1 size:16384
21:20:21.698 T:2680890224 ERROR: Open - error probing input format, pvr://channels/tv/Wszystkie/pvr.dvbviewer_332.pvr
21:20:22.558 T:2680890224 ERROR: Previous line repeats 2 times.
21:20:22.558 T:2680890224 DEBUG: ffmpeg[9FCB2370]: Probing mp3 score:1 size:2048
21:20:22.559 T:2680890224 DEBUG: ffmpeg[9FCB2370]: Probing mp3 score:1 size:4096
21:20:22.561 T:2680890224 DEBUG: ffmpeg[9FCB2370]: Probing mp3 score:1 size:8192
21:20:22.564 T:2680890224 DEBUG: ffmpeg[9FCB2370]: Probing mp3 score:1 size:16384
21:20:22.985 T:2680890224 ERROR: Open - error probing input format, pvr://channels/tv/Wszystkie/pvr.dvbviewer_332.pvr
21:20:23.415 T:2680890224 ERROR: Previous line repeats 1 times.
21:20:23.415 T:2680890224 DEBUG: ffmpeg[9FCB2370]: Probing mp3 score:1 size:8192
21:20:23.418 T:2680890224 DEBUG: ffmpeg[9FCB2370]: Probing mp3 score:1 size:16384
21:20:23.838 T:2680890224 ERROR: Open - error probing input format, pvr://channels/tv/Wszystkie/pvr.dvbviewer_332.pvr
21:20:24.272 T:2680890224 ERROR: Previous line repeats 1 times.
21:20:24.272 T:2680890224 DEBUG: ffmpeg[9FCB2370]: Probing mp3 score:1 size:16384
21:20:24.691 T:2680890224 ERROR: Open - error probing input format, pvr://channels/tv/Wszystkie/pvr.dvbviewer_332.pvr
