This is an issue which I have had since I migrated to Coreelec. When I go into my music collection and select into an album to get the tracks listing, I find that if I click on the first track it plays that track but then stops. I have “play next track” selected in the Player settings so it should play the next tracks in turn until it reaches the end of the album. The only way I can get it to play the next track is to select each in turn one by one or que them. Another option is to go back a menu level and select the album and use the context menu to play this item on the whole album.
This is not how it used to behave, and I am certain that it is not the way it is intended to behave. The reason I say this is because on my other box, running on a RaspPi 2 with Leia beta 4, it works as expected, ie it plays all the tracks in a folder in turn until it runs out if “play next track” is selected in settings.
This is a minor feature of functionality, but it is highly annoying that it is “broken” and doesn’t behave as described. Can anyone else confirm this broken behaviour.
