Is there any mod to make player process info to also show hardware temperature & network speed?
What you are asking for is not useful for a simple CoreELEC user. If you want to manage CoreELEC in a simple way you can use your smartphone and load the Termius application (ssh client).
The commands to see
- information processes: top
- CPU temperature: cputemp
- internet speed test: the following script /storage/speedtest.sh
#!/bin/sh
curl -s https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py | python -
Note.- I have some CoreELEC devices very far away and I monitor them through the internet using SSH. A mod to see the information on the screen is useless for me.
As far as network speed, on osmc skin, there is an option when in player process info, if you press ok it shows player debug info & network speed is shown. I guess an “on click” keymap command for some button would do the job, but I don’t know that much to figure it out
