Is it possible to create an image compatible with Amlogic burning tool.
If not, why it hasn’t possible yet?
I doubt it since the AMLogic burn tool checks signatures of images before burning them. If you can work out how to generate a signature then maybe.
Thanks, @Shoog.
I’d like invest some time into it. Do you have have any idea/suggestion where should I start looking?
Sorry its beyond my expertise.
