Hm, automatic retart does not helped on real panics. No reboot happened. I’ve compiled u-boot with 720MHz. It not helped with panics, but now player reboots on panic. I’ve been able to collect two oopes:
https://pastebin.com/jUgJbCmm
https://pastebin.com/5uSP1Lz2
https://pastebin.com/80Y5kGh4
https://pastebin.com/CJB8Ze5c
I don’t know if it is something with the scheduler, or the memory is corrupted.
Exclude support for RTL-PHY Driver from the board config file and WOL Support from the Suspend_FW and recompile the uboot. Use the 16Gb-32Gb SDcard for CE.
Box became very unstable. I’ve got a little time for experiments this weekend.
I’ve downloaded original firmware from Vorke Z6 Plus and tried to flash that, but got freezes on the start of the process. I’ve unpacked firmware and flashed bootloader from sd card from inside u-boot by UART.
It showed me 684MHz rate. Looks like I’ve had wrong bootloader initially.
On the first glance it became more stable, but I’ve not been able to watch “Lost In London” it freezes in first 15 minutes of that particular film.
I’ll try to do more tests
