Hey guys,
jI hope you can give me a hint on why building via create_addon fails…
My Environment:
- brand new Virtualbox with 80GB
- Fresh and updated Ubuntu 16.04 Server
- CoreELEC master checkout
command line:
PROJECT=Amlogic DEVICE=Odroid_C2 ARCH=arm scripts/create_addon hyperion.ng
/home/anthrax/CoreELEC/build.CoreELEC-Odroid_C2.arm-9.0-devel/Python3-3.7.0/setup.py build
running build
running build_ext
INFO: Can't locate Tcl/Tk libs and/or headers
INFO: Could not locate ffi libs and/or headers
Python build finished successfully!
The necessary bits to build these optional modules were not found:
_dbm _gdbm _lzma
_tkinter _uuid nis
To find the necessary bits, look in setup.py in detect_modules() for the module's name.
The following modules found by detect_modules() in setup.py, have been
built by the Makefile instead, as configured by the Setup files:
_abc atexit pwd
time
Failed to build these modules:
_ctypes
make: *** [Makefile:620: sharedmods] Error 1
ADDON FAILED hyperion.ng
I tried two hours messing arround with libffi-dev paths CFLAGS, LDFLAGS, PKG_CONFIG_PATH, and what not… but always ran into this error.
any guidance?
best regards
Anthrax
