Hi, first, my best compliments for your work! CoreELEC works like a charm!
I’ve update from 8.90.1 to 8.90.2. All seems work fine except the dowload of EPG giude on pvr.iptvsimple plugin.
The problem seems to be on CCurlFile configuration. This is the log of errors:
12:22:59.374 T:4097445904 NOTICE: PVR Manager: Starting
12:22:59.540 T:3685225328 NOTICE: PVR Manager: Started
12:22:59.541 T:3809571696 NOTICE: Start - EPG thread started
12:23:01.858 T:3767608176 ERROR: CCurlFile::FillBuffer - Failed: SSL peer certificate or SSH remote key was not OK(51)
12:23:01.858 T:3767608176 ERROR: CCurlFile::Open failed with code 0 for https://www.epg-guide.com/it.gz
12:23:01.864 T:3767608176 ERROR: Open - failed to open source <https://www.epg-guide.com/it.gz>
12:23:01.864 T:3767608176 ERROR: AddOnLog: PVR IPTV Simple Client: Unable to load EPG file 'https://www.epg-guide.com/it.gz': file is missing or empty. :1th try.
12:23:04.032 T:3767608176 ERROR: CCurlFile::FillBuffer - Failed: SSL peer certificate or SSH remote key was not OK(51)
12:23:04.032 T:3767608176 ERROR: CCurlFile::Open failed with code 0 for https://www.epg-guide.com/it.gz
12:23:04.036 T:3767608176 ERROR: Open - failed to open source <https://www.epg-guide.com/it.gz>
12:23:04.036 T:3767608176 ERROR: AddOnLog: PVR IPTV Simple Client: Unable to load EPG file 'https://www.epg-guide.com/it.gz': file is missing or empty. :2th try.
12:23:06.231 T:3767608176 ERROR: CCurlFile::FillBuffer - Failed: SSL peer certificate or SSH remote key was not OK(51)
12:23:06.232 T:3767608176 ERROR: CCurlFile::Open failed with code 0 for https://www.epg-guide.com/it.gz
12:23:06.236 T:3767608176 ERROR: Open - failed to open source <https://www.epg-guide.com/it.gz>
I have downgrade to 8.90.1 and all works fine again.
Thanks for your support in advance.
