Hello there,
I just got a ODroid N2+ and I’m running into some issues. My N2+ is connected to a Pioneer receiver. I have 2 displays, 1 Pioneer Plasma and 1 Sony Projector.
My issue is very weird so please stick with me
First of all, if the TV is off, I cannot connect to the N2+ using ssh even though the receiver is on.
If I turn the TV on, then I can ssh.
Before the N2+ I was using a Vero4K and I had no issues connecting to it using ssh with the TV off.
Another issue I noticed is that I cannot use the N2+ on the projector if the TV is off.
I get no signal. In order to get the signal on the projector, the TV needs to be on.
Again, I didn’t have this issue with the Vero4K, nor with my NUC with Windows on it, or my old ChromeBOX with LibreELEC on it. It’s also working fine with my UHD player or my BD player.
So it’s really only happening with the N2+
So the question is, what am I missing? Is there an option I need to disable or something I need to enable?
Btw, I have disabled all the CEC options but it did not make a difference.
Is there a log I can provide or more specific infos?
Thanks a lot for any help I can get.
