Magnus
12 November 2020 04:22
#1
Ugoos am6 PLUS S922X. Any audio content is output in 16 bits. I launch high res audio and check the output. S16LE. Please specify one more format in the audio driver - S32LE
hdmi:CARD=AMLM8AUDIO,DEV=0
NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
OMG
All developers stopped everything and now they are all working on it, but no time to write in the forum
a little patience please
I have this output on N2+ for 2ch 192kHz sample. I don’t have 192kHz 8ch sample
CoreELEC-N2Plus:~ # cat /proc/asound/AMLAUGESOUND/pcm*p/sub*/hw_params
closed
closed
closed
access: MMAP_INTERLEAVED
format: S24_LE
subformat: STD
channels: 2
rate: 192000 (192000/1)
period_size: 8192
buffer_size: 32768
Magnus
12 November 2020 18:24
#5
flac 24 bit
KODI:~ # cat /proc/asound/AMLAUGESOUND/pcmp/sub /hw_params
access: RW_INTERLEAVED
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 2205
buffer_size: 8820
Magnus
13 November 2020 08:34
#6
And how to ban amixer? I love hardware sound. The sound is now being mixed.
FLAC cannot be bitstreamed. You can only bitstream\passthrough Dolby and DTS formats.
Magnus
14 November 2020 18:07
#8
Spdif only 16 bit sound. Sad. No hi-res
Magnus
20 November 2020 06:11
#9
Dear developers, please make 24 bit sound for spdif
The driver specifies S16LE, S24LE and S32LE. Kodi must be filtering it out.
From what I could see, passthrough is automatically dialed in to S16LE.
Magnus
22 November 2020 13:49
#11
There are no such problems on Intel and Libreelec. SPDIF is 24 bit
x86 platforms use a completely different set of audio Sinks. It’s just the way the ALSA sink has been written, at least as far as I can tell.
system
closed
21 February 2021 20:04
#13
