This isn’t a general ‘pvr addons won’t install’ - I had no problem installing pvr.iptvsimple on 8.95.5.
With dvbviewer I had no success.
Edit: see end of post - it’s working after a direct download and install from zip.
I tried on 8.95.5 first:
I saw 3 options in the repo when trying to install:
3.7.7.2
3.7.3.2
3.7.3.2 (yes, 2 versions the same)
Firstly I tried 3.7.7.2
Result:
‘CCurlFile::Open failed with code 404 for https://addons.coreelec.org/9.0/Amlogic/arm/pvr.dvbviewer/pvr.dvbviewer-3.7.7.2.zip:’
I checked the repo in my browser, and indeed there is only one version visible (3.7.3.2)
So I tried that one:
‘The dependency on kodi.binary.instance.pvr version 5.10.3 could not be satisfied.’
Log is here.
@12:45:23.082 Can’t find 3.7.7.2
@12:46:14.772 try to install 3.7.3.2
I stopped kodi, deleted addons27.db, restarted and tried again. Exactly the same results.
Log is here. - nothing new to see.
I then installed the latest nightly:
CoreELEC-S905.arm-9.0-nightly_20181127
I was unable to connect to the coreelec nighlt repo:
‘CAddonDatabase: no valid repository matching ‘repository.cenightly’/arm/addons.xml.gz?sha256:’’
Log is here.
See 13:20:38.043 for failed connection.
Edit:
Now for the bit that really stumped me…
I downloaded 3.7.3.2 from the repo in my browser.
Unzipped, opened addons.xml and the dependency is correct (5.10.4).
I tried an install from zip in 5.95.5 and it worked fine.
Something’s screwy somewhere…anyone???
