So i Was under the impression that wp2 is supported out of the box. So upon first use the only buttons to work are power volume channels and a few others.
I went about trying to create a new map using ir-keytable -t. Part way through the first few commands, I realized i was basically just creating an exact copy of what is already under wetek_play_2 rc-keymaps files.
So I installed the keymap editor to manually appoint the keys, but so many buttons have the same “key id” that its not behaving as expected.
For e.g. [*] on the wetek remote carries 61592 but so does the [≡] so if i set it to context menu when i press [*] it also shows context menu.
