I just installed coreelec to a mecool m8s pro plus (S905x) and copied gxl_p212_2g.dtb to dtb.img.
I tried to reboot android from internal by selecting boot from emmc/nand but the box rebooted to coreelec.
after manually trying to launch rebootfromnand im getting this error:
CoreELEC:~ # /usr/sbin/rebootfromnand
Cannot parse config file '/etc/fw_env.config': Invalid argument
Error: environment not initialized
CoreELEC:~ # fw_printenv
CoreELEC:~ # cat /etc/fw_env.config
# Configuration file for fw_(printenv/setenv) utility.
# Up to two entries are valid, in this case the redundant
# environment sector is assumed present.
# Notice, that the "Number of sectors" is not required on NOR and SPI-dataflash.
# Futhermore, if the Flash sector size is ommitted, this value is assumed to
# be the same as the Environment size, which is valid for NOR and SPI-dataflash
# NOR example
# MTD device name Device offset Env. size Flash sector size Number of sectors
#/dev/mtd1 0x0000 0x4000 0x4000
#/dev/mtd2 0x0000 0x4000 0x4000
# MTD SPI-dataflash example
#/dev/mtd5 0x4200 0x4200
#/dev/mtd6 0x4200 0x4200
# NAND example
#/dev/mtd0 0x4000 0x4000 0x20000 2
# Block device example
#/dev/mmcblk0 0xc0000 0x20000
# VFAT example
#/boot/uboot.env 0x0000 0x4000
# Amlogic NAND
/dev/nand_env 0x000000 0x10000 0x10000
# Amlogic eMMC
/dev/env 0x000000 0x10000 0x10000
CoreELEC:~ # ls /dev/nand_env
ls: /dev/nand_env: No such file or directory
CoreELEC:~ # ls /dev/env
ls: /dev/env: No such file or directory
CoreELEC:~ # ls /flash/ -lah
total 160224
drwxr-xr-x 3 root root 16.0K Jan 1 1970 .
drwxrwxr-x 12 root root 202 Sep 15 03:19 ..
-rwxr-xr-x 1 root root 146.7M Sep 15 04:20 SYSTEM
-rwxr-xr-x 1 root root 48 Sep 15 04:20 SYSTEM.md5
-rwxr-xr-x 1 root root 795 Sep 15 04:20 aml_autoscript
drwxr-xr-x 2 root root 8.0K Sep 15 04:20 device_trees
-rwxr-xr-x 1 root root 39.8K Sep 28 18:07 dtb.img
-rwxr-xr-x 1 root root 9.6M Sep 15 04:20 kernel.img
-rwxr-xr-x 1 root root 48 Sep 15 04:20 kernel.img.md5
CoreELEC:~ # cat /etc/release
S905.arm-8.95.2
