**Odriod N2 **
Some random Hisense TV remote I programmed.
First off, love the work you guys do and the loads of support if got from this forum! I’ve been having a weird issue. Every since the last update I have done my remote is behaving weird. I followed to pinned guide and programmed my tv remote successfully. Remote has been working for months now. All of sudden after 5 min it doesn’t work at all and is rendered useless. After I reboot it works fine for the first minute or too, then back to not working at all I can’t wrap my head around it any help is greatly appreciated. If I need to provide a log and I can if it helps thanks.
Not sure why… but this issue was resolved after fresh install.
