Trying to figure out why you seem to be getting different results with retroplayer then other users with the s912.
Just want confirmation that the retroplayer emulators are working. You get a picture in nestopia and roms are playable?
Gave this a fast try on my S912 as it was quite many releases ago when I tried it the last time. VRAM test and Nestopia still gives me the same black screen but FCEUmm seemingly works.
Hi, no my results are the same as Rascal. FCEUmm runs all nes roms
The VRAM test, it worked the first time but not now?
The VRAM test is only visible when paused.I see whats causing the confusion now- Test Pattern Visible: YES should have read only when paused.
Device Tested: T95Z Max (s912 2/16/1 gbit)
Image Used: CoreELEC-S912.arm-8.95.6-S912.img.gz
DTB File Used: gxm_q201_2g_1gbit.dtb
Test Pattern Visible: no (or yes, only when paused)
Display Used: Monitor (AOC Q3279VWF)
Screen Resolution: 1080p
Does your Display Support: yes (“10-bit colour is supported through 8-bit + FRC dithering”)
Some good news on the Retroplayer front.
I recently got a Le Potato(It’s an s905x) to test with, and was able to sort out the retroplayer black screen issue on s905x devices.
for anybody that wants to try…
https://drive.google.com/drive/folders/1dsFWEpuBkll2JnEkXwlxb2jfmJPOi1TL
edit: added the s912 builds as well. However due to lack of a s912 device to test with I don’t know if the problem is resolved for s912 as well.
Image Used: CoreELEC-S912.arm-9.0-devel-fh-1904.7-S912.img.gz
Test Pattern Visible: YESSSSS
@felixwolf Thanks, for trying the test build.
Device Tested: Mini M8S II
Image Used: CoreELEC-S905.arm-9.0-devel-fh-1904.7
DTB File Used: gxl_p212_1g.dtb
Test Pattern Visible: yes
Display Used: TV
Does your Display Support: HDR or 10bit colour: no
Thank you very much. I’ve tested also Bomberman game addon and other NES games/roms using Nestopia emulator. All good!
@cdu13a Thank you, for the effort and the result.
