Hi!
I´m running latest CE Build on my S905X Box.
When i change Colorspace in System settings nothing happens.
I don´t know which colorspace is used.
Any conclusion?
Thx in advance!
b0mb
Hi!
Any conclusion?
Thx in advance!
b0mb
Where\how\why are you changing the colospace?
Also, you need to follow up with a resolution or refresh change for the colorspace change to take effect.
In the System Settings of CE when i choose 16-235 the change does have no effect.
Also after a reboot everything was like before…
This feature can work(if it work) for rgb mode only.
By default you use yuv444,8bit
but on LE on my NUC i´ve deselected 16-235 and the system switched to RGB mode 0-255 and that is what it not does actually…
btw how can i check the actual screen mode via console?
This isn’t a NUC, it’s a completely different platform, with different capabilities.
You can see the current configuration with the following command:
cat /sys/class/amhdmitx/amhdmitx0/attr
You’ll probably see something like 444,8bit
I just took another look, and there’s no such option in CE.
And correction to my above post, by default, cat .../attr
will return an empty string.
with the latest update the option is not available anymore
It’s actually cat /sys/devices/virtual/amhdmitx/amhdmitx0/config
cur_VIC: 16
cur_video_param->VIC=16
cd = 5
cs = 2
VIC are explained here https://en.wikipedia.org/wiki/Extended_Display_Identification_Data
