had problems with the ip address (169.254.X.X) after installing the CE. But after flashing the android port from ugoos the nightlys work correctly, now ip is correct. I use dtb g12b_s922x_x88_king_rev_a. The display hbs658 works, below is the display config. There are problems with starting the Nexus after flashing the box. On Nexus, after turning power off or reboot you need to hold the reset every time to start the firmware. Everything works well on the matrix rc5. For now от Nexus have to press reset button every time to start, everything else is correct. I have box version 4/64.
hbs658 vfd.conf
vfd_gpio_clk=‘0,0x17,0x10’
vfd_gpio_dat=‘0,0x18,0x10’
vfd_gpio_stb=‘0,0,0xFF’
vfd_chars=‘4,0,1,2,3’
vfd_dot_bits=‘0,1,2,3,4,5,6’
vfd_display_type=‘0x06,0x00,0x00,0x04’
