Hi, was wandering if this can be done.
Currently, the BCM43752A2 (SDIO, chip rev aae8/2) on RockTek G2 (Nokia 8010) currently loads firmware 18.35.387.11 (2019-12-04) via the dhd driver 101.10.591.84.38.
Radio advertises full HE/802.11ax capabilities in iw phy but never associates using HE — station dump shows no HE-MCS field, only VHT-rate values.
Requesting an updated fw_bcm43752a2_ag.bin/clm_bcm43752a2_ag.blob with HE association support, and confirmation of the correct SDIO nvram file for this chip.
Thank you.
