Hello, i hope anybody can help me with my “small” problem. Since yesterday, i have a W95 S905W Box (https://www.ebay.de/itm/W95-Amlogic-S905W-Android-7-1-2GB-16GB-3D-4K-HD-WIFI-Smart-TV-BOX-Multi-Media/132812528620?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649).
I have also install Coreelec to internal and it’s run fine. But if i shutdown my W95 Box with Coreelec and Make my TV off and after a while on, my AV receiver goes not on. he stays out. If i remove my W95 Box or start the box, the Receiver goes on. If i make the receiver via receiver remote on, the receiver has no sound and he did not show the correct audio info.
There must be a problem with the W95 box. With my odroid c2 i have not these problem.
Try the following in SSH
fw_setenv cecconfig cec3f
reboot
Sorry, this did not help. After removing the HDMI cable, all is normaly.
This is a buggy u-boot from your vendor. There is nothing we can do since we only build u-boot for LePotato, Odroid C2, KVIM and KVIM2.
Ok, thanks. Thats not so good.
Another question, is it possible to power on the Odroid-C2 with another remote than the original Hardkernel remote?
Yes but you would have to compile your own bootloader with the ‘other’ remote power on code.
Also try our nightly release as there has been some CEC changes which may help.
@Mister-XY I don’t know which remote you have but it is possible with some of the harmony remotes(or any remote that can learn from another remote) to record the the power on code from the original hardkernel remote and use it as the power on code for the harmony remote.
However the exact details of how to do this I’m however not familiar with.
I have a Harmony but the remote is very slow.
We found something interesting in uboot lately with @Portisch
https://github.com/CoreELEC/u-boot/blob/libretech/arch/arm/cpu/armv8/gxl/firmware/scp_task/scp_remote.c#L236
https://github.com/CoreELEC/u-boot/blob/libretech/arch/arm/cpu/armv8/gxl/firmware/scp_task/user_task.c#L137
It means we can define our own power key from Kernel.
But this has to be implemented.
Thats very nice
I know, that i have for round about 2 years the same issue with the odroid. There was a problem with u-boot or with the device tree. i know thats was a build from wrxtasy from odroid forum. I will look for that build and show the different.
Today i have test my old Meccol M8 box. and this box has not the CEC hijacking error
i make via fw_printenv a log
1080p_h=1028
1080p_w=1826
1080p_x=47
1080p_y=26
EnableSelinux=permissive
baudrate=115200
bootargs=rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.selinux=permissive logo=osd1,loaded,0x3d800000,1080p60hz maxcpus=4 vout=1080p60hz,enable hdmimode=1080p60hz cvbsmode=576cvbs hdmitx= cvbsdrv=0 androidboot.firstboot=0 jtag=apao androidboot.hardware=amlogic mac=D0:76:58:08:86:A0 androidboot.mac=D0:76:58:08:86:A0
bootcmd=if test ${bootfromnand} = 1; then setenv bootfromnand 0; saveenv; else run librefromsd; run librefromusb; fi; run storeboot
bootdelay=1
bootfromnand=0
bootup_offset=0x115f000
bootup_size=0xb85a8
cmdline_keys=if keyman init 0x1234; then if keyman read usid ${loadaddr} str; then setenv bootargs ${bootargs} androidboot.serialno=${usid};fi;if keyman read mac ${loadaddr} str; then setenv bootargs ${bootargs} mac=${mac} androidboot.mac=${mac};fi;if keyman read deviceid ${loadaddr} str; then setenv bootargs ${bootargs} androidboot.deviceid=${deviceid};fi;fi;
cvbs_drv=0
cvbsmode=576cvbs
display_bpp=16
display_color_bg=0
display_color_fg=0xffff
display_color_index=16
display_height=1080
display_layer=osd1
display_width=1920
dtb_mem_addr=0x1000000
ethact=dwmac.c9410000
ethaddr=00:15:18:01:81:31
factory_reset_poweroff_protect=echo wipe_data=${wipe_data}; echo wipe_cache=${wipe_cache};if test ${wipe_data} = failed; then run init_display; run storeargs;if mmcinfo; then run recovery_from_sdcard;fi;if usb start 0; then run recovery_from_udisk;fi;run recovery_from_flash;fi; if test ${wipe_cache} = failed; then run init_display; run storeargs;if mmcinfo; then run recovery_from_sdcard;fi;if usb start 0; then run recovery_from_udisk;fi;run recovery_from_flash;fi;
fb_addr=0x3d800000
fb_height=1080
fb_width=1920
fdt_high=0x20000000
filesize=409
firstboot=0
gatewayip=10.18.9.1
hdmimode=1080p60hz
hostname=arm_gxbb
init_display=osd open;osd clear;imgread pic logo bootup $loadaddr;bmp display $bootup_offset;bmp scale
initargs=rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000
ipaddr=10.18.9.97
irremote_update=irkey 0xba45ff00 0xba4594ca 1002000;if test ${irkey_value} = update; then run update;else if test ${irkey_value} = update_sdcard; then run update_sdcard;else if test ${irkey_value} = usb_burning; then run usb_burning;else if test ${irkey_value} = update_udisk; then run update_udisk;fi;fi;fi;fi;
jtag=apao
librefromsd=if mmcinfo; then if fatload mmc 0 ${loadaddr} kernel.img; then run sddtb; setenv bootargs ${bootargs} bootfromsd; bootm; fi; fi
librefromusb=if usb start 0; then if fatload usb 0 ${loadaddr} kernel.img; then run usbdtb; setenv bootargs ${bootargs} bootfromusb; bootm; fi; fi
loadaddr=1080000
maxcpus=4
netmask=255.255.255.0
outputmode=1080p60hz
preboot=run factory_reset_poweroff_protect;run upgrade_check;run init_display;run storeargs;run upgrade_key;run update_key;run irremote_update;run switch_bootmode;
reboot_mode=normal
recovery_from_flash=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if imgread kernel ${recovery_part} ${loadaddr} ${recovery_offset}; then wipeisb; bootm ${loadaddr}; fi
recovery_from_sdcard=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if fatload mmc 0 ${loadaddr} aml_autoscript; then autoscr ${loadaddr}; fi;if fatload mmc 0 ${loadaddr} recovery.img; then if fatload mmc 0 ${dtb_mem_addr} dtb.img; then echo sd dtb.img loaded; fi;wipeisb; bootm ${loadaddr};fi;
recovery_from_udisk=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if fatload usb 0 ${loadaddr} aml_autoscript; then autoscr ${loadaddr}; fi;if fatload usb 0 ${loadaddr} recovery.img; then if fatload usb 0 ${dtb_mem_addr} dtb.img; then echo udisk dtb.img loaded; fi;wipeisb; bootm ${loadaddr};fi;
recovery_offset=0
recovery_part=recovery
sdc_burning=sdc_burn ${sdcburncfg}
sdcburncfg=aml_sdc_burn.ini
sddtb=if fatload mmc 0 ${dtb_mem_addr} dtb.img; then echo sd dtb.img loaded; else store dtb read $dtb_mem_addr; fi
serverip=10.18.9.113
stderr=serial
stdin=serial
stdout=serial
storeargs=setenv bootargs ${initargs} androidboot.selinux=${EnableSelinux} logo=${display_layer},loaded,${fb_addr},${outputmode} maxcpus=${maxcpus} vout=${outputmode},enable hdmimode=${hdmimode} cvbsmode=${cvbsmode} hdmitx=${cecconfig} cvbsdrv=${cvbs_drv} androidboot.firstboot=${firstboot} jtag=${jtag}; setenv bootargs ${bootargs} androidboot.hardware=amlogic;run cmdline_keys;
storeboot=if imgread kernel boot ${loadaddr}; then bootm ${loadaddr}; fi;run update;
switch_bootmode=get_rebootmode;if test ${reboot_mode} = factory_reset; then run recovery_from_flash;else if test ${reboot_mode} = update; then run update;else if test ${reboot_mode} = cold_boot; then fi;fi;fi;
try_auto_burn=update 700 750;
update=run usb_burning; run sdc_burning; if mmcinfo; then run recovery_from_sdcard;fi;if usb start 0; then run recovery_from_udisk;fi;run recovery_from_flash;
update_key=saradc open 0; if saradc get_in_range 0 0x50; then msleep 50; if saradc get_in_range 0 0x50; then echo update by key…; run update; fi;fi
update_sdcard=if mmcinfo; then run recovery_from_sdcard;fi;
update_udisk=if usb start 0; then run recovery_from_udisk;fi;
upgrade_check=echo upgrade_step=${upgrade_step}; if itest ${upgrade_step} == 3; then run init_display; run storeargs; run update;else fi;
upgrade_key=if gpio input GPIOAO_2; then echo detect upgrade key; sleep 3;if gpio input GPIOAO_2; then run update; fi;fi;
upgrade_step=2
usb_burning=update 1000
usbdtb=if fatload usb 0 ${dtb_mem_addr} dtb.img; then echo usb dtb.img loaded; else store dtb read $dtb_mem_addr; fi
wipe_cache=successful
wipe_data=successful
and that is the log from the w95 (beelink) box
active_slot=_a
aml_dt=gxl_p281_2g
baudrate=115200
bcb_cmd=get_valid_slot;
boot_part=boot
bootcmd=if test ${bootfromnand} = 1; then setenv bootfromnand 0; saveenv; else run bootfromsd; run bootfromusb; fi; run storeboot
bootdelay=1
bootfromnand=0
bootfromsd=mmcinfo; if fatload mmc 0 ${loadaddr} kernel.img; then run sddtb; setenv bootargs ${bootargs} bootfromsd; bootm; fi
bootfromusb=usb start 0; if fatload usb 0 ${loadaddr} kernel.img; then run usbdtb; setenv bootargs ${bootargs} bootfromusb; bootm; fi
cmdline_keys=if keyman init 0x1234; then if keyman read usid ${loadaddr} str; then setenv bootargs ${bootargs} androidboot.serialno=${usid};setenv serial ${usid};fi;if keyman read mac ${loadaddr} str; then setenv bootargs ${bootargs} mac=${mac} androidboot.mac=${mac};fi;if keyman read deviceid ${loadaddr} str; then setenv bootargs ${bootargs} androidboot.deviceid=${deviceid};fi;fi;
cvbs_drv=0
cvbsmode=576cvbs
display_bpp=16
display_color_bg=0
display_height=1080
display_layer=osd1
display_width=1920
fb_addr=0x3d800000
fb_height=1080
fb_width=1920
fdt_high=0x20000000
firstboot=0
gatewayip=10.18.9.1
hdmimode=1080p60hz
hostname=arm_gxbb
ipaddr=10.18.9.97
jtag=apao
loadaddr=1080000
preboot=run bcb_cmd; run factory_reset_poweroff_protect;run upgrade_check;run init_display;run storeargs;run upgrade_key;run switch_bootmode;
recovery_from_flash=setenv bootargs ${bootargs} aml_dt=${aml_dt} recovery_part={recovery_part} recovery_offset={recovery_offset};if itest ${upgrade_step} == 3; then if ext4load mmc 1:2 ${dtb_mem_addr} /recovery/dtb.img; then echo cache dtb.img loaded; fi;if ext4load mmc 1:2 ${loadaddr} /recovery/recovery.img; then echo cache recovery.img loaded; wipeisb; bootm ${loadaddr}; fi;else fi;if imgread kernel ${recovery_part} ${loadaddr} ${recovery_offset}; then wipeisb; bootm ${loadaddr}; fi;
recovery_offset=0
sddtb=if fatload mmc 0 ${dtb_mem_addr} dtb.img; then else store dtb read $dtb_mem_addr; fi
storeargs=setenv bootargs ${initargs} androidboot.selinux=${EnableSelinux} logo=${display_layer},loaded,${fb_addr},${outputmode} maxcpus=${maxcpus} vout=${outputmode},enable hdmimode=${hdmimode} cvbsmode=${cvbsmode} hdmitx=${cecconfig} cvbsdrv=${cvbs_drv} androidboot.firstboot=${firstboot} jtag=${jtag}; setenv bootargs ${bootargs} androidboot.hardware=amlogic;run cmdline_keys;setenv bootargs ${bootargs} androidboot.slot_suffix=${active_slot};
storeboot=if imgread kernel ${boot_part} ${loadaddr}; then bootm ${loadaddr}; fi;run update;
switch_bootmode=get_rebootmode;if test ${reboot_mode} = factory_reset; then run recovery_from_flash;else if test ${reboot_mode} = update; then run update;else if test ${reboot_mode} = cold_boot; then run try_auto_burn; else if test ${reboot_mode} = fastboot; then fastboot;fi;fi;fi;fi;
upgrade_step=2
usbdtb=if fatload usb 0 ${dtb_mem_addr} dtb.img; then else store dtb read $dtb_mem_addr; fi
I use on both system the new coreelec Version
Unfortunately this is not an env problem. It’s a bug in u-boot. We will not be able to fix it. C2 is still affected because it uses an older u-boot. I have the intention to update C2 uboot but it means to drop some of Hardkernel commits. Now my main device is Lepotato and I’m moving interesting HK code over to it’s u-boot so hopefully we will be able to update C2 too.
Ok, but i see, not all the cheap amlogic boxes has this error.
