MXQ Pro 4k / S905X. Boot from sdcard. It works, but some problems are there:
- it sometimes boots to Android, sometimes boot from sdcard. Sdcard is inserted all the time. If I try to boot from recovery (with reset button pressed), it sometimes boots to coreelec from sdcard, sometimes it just shows recovery and does not boot from sdcard
- when booted, it works just fine. However, after suspend with remote (led color is red), it’s not possible to wake up anymore with remote. Need to disconnect power supply and connect again.
I also own slightly newer MXQ Pro 4k, with S905W and there is no such problem. It always boots to coreelec and suspend/wake up works correctly.
Is that looks like some kind of physical damage (recently, analog audio output stopped working, both Android and Coreelec, could it be related), or I should try with some other dtb?
