Alright, thanks. I think we’ve dealt with this before.
It didn’t reproduce for me today, but I’ll make sure to create a log when it happens.
Just out of curiosity, if it is a problem with the instance-guard, is there a solution?
For Amlogic we can remove it as there isn’t concurrent playback of two video streams (e.g. PIP).
BTW I pushed patch for avoiding possible issues with instace-guard.
It just reproduced for me, and here’s the relevant bit from the log:
23:37:55.349 T:3213853552 NOTICE: CVideoPlayerVideo::OpenStream - Creating codec: 27
23:37:55.349 T:3213853552 ERROR: CDVDVideoCodecAmlogic::Open - InstanceGuard locked
23:37:55.349 T:3213853552 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
23:37:55.350 T:3213853552 DEBUG: CDVDVideoCodecFFmpeg - Updated codec: ff-h264
23:37:55.350 T:3213853552 DEBUG: CVideoPlayerVideo::OpenStream - open stream with codec id: 27 fps:25/1 options:02
So if I understand correctly, the change you pushed earlier will prevent this problem from happening again?
I need complete log to see CE version and error messages! Try to upgrade to 8.95.3 or the latest nightly build.
Yes, this is an older build, before the change you’ve made to the instanceguard.
I will try the latest over the weekend and see if there are still problems with it.
H96 Pro here. Same issue since 9.0.3 and nightlies. All videos play with software. Flashing back to 9.0.2 fixes it.
This is not the same problem, open a new thread.
Sorry. I’ve created a new thread: [Solved] H96 Pro Hardware decoding not working with 9.0.3 and above
