I have android box with s912 32Gb/3GB.
When i install coreelec 8.95.3 (or any coreelec) then, when i play video (no metter 1080P or UHD) frames start skipping.
If i install Libreelec with KODI 17.1 videos are working normaly.
Does anybody else have this problem?
You have to select all required resolutions and refresh rates in Whitelist settings
Try 8.95.2. I also have problems in 8.95.3 that I do not have with 8.95.2. It is not the exact same problem but similar. Maybe it works out for you. You just need to download the correct .tar file and put it in your .update folder and reboot.
