Did you copy g12b_s922x_ugoos_am6_rev_a.dtb to root of sd card and renamed it to dtb.img?
If you have big sd card it will take some time to resize it… but not so much time.
new devices are only a revision… b just have better core speeds.
so I tried with previous nightly and now it worked better, I’m inside CE now. how do I start the ceemmc tool?
read an instruction fully (hint in the end of it )
yes , but it works for this box
Just out of curiosity; why go for the Ugoos box when the Odroid N2 2gb is just €60 (€65 with the kit)?
yes but I just want to know how to start the tool, I guess using Putty?
https://discourse.coreelec.org/t/how-to-remote-control-configuration-for-dummies-using-windows-and-ssh/477
here there is a pdf instruction that includes how to connect…
via Putty ssh for example
because for us European citizens it’s not only €65 and I want a good WiFi chip which the Ugoos have also 2 external antennas does it even better, the N2 WiFi Module 5A was CRAP it even buffered 1080p videos, sure I can use Ethernet but I prefer using my devices wireless, if the Nvidia Shield can playback my 4K files wireless then the Ugoos should too.
thank you!
wow that was easy, now the AM6 is running CE from eMMC, nice!
OK, I just wanted to know about your thoughts. I do also live in Europe, and the tolls/fees hurts a bit of course. But I think it is still cheaper than the Ugoos, as is. But if the wifi is a dealbreaker I will not continue to argue with you.
Me personally wouldn’t dream to connect these boxes wirelessly though, despite that I have a rather mature Ubiquiti network. But it is okay to not agree.
Congratulations on your success! I’m new to this forum and a AM6 owner who wants to install CE on it. I have read the documents and feel confident in proceeding except for the major problem of not knowing where to obtain .img.gz file and device tree. I would greatly appreciate some directions to the files. Thanks
From our download page. And use latest -ng nightly.
I’m not sure but I think CEC wakeup is not working properly, sometimes it won’t turn on my soundbar, I have to turn off the box and then it will work, I read about something to do with uboot, is it possible to make it work properly for this box? or any workaround? thanks
AM6 -> HW-N960 -> LG OLED C8.
May be it could fix your CEC issue
thanks, does this apply to the Odroid N2 as well?
No, N2 already have own u-boot
AM6 coreelec , 3.5 jack analog audio does not work (Build NG 20191204) , Anybody have solution? thanks you
Does CE work with AM6 Pro (4/32) version?
