Would it be possible to install a function with which it is possible to save all settings, including the addons?
This would make it easier after a clean reinstall the settings to play back, you would not always reconfigure everything, eg. There are similar features in OpenATV images
as far as I can se, all addons, skin, thumbnails, settings etc. will be saved.
When I do a fresh install and restore my CE-backup, the behaviour and functionality is the same as before (beside the new CE-function/fixes).
