I’m posting this here as I cannot find the issues section on github. I’ve just reinstalled laptop so it might be something to do with my noscript settings.
Anyway -----------
I’ve had this issue since 8.90.1 but thought it was due to the dirty installs I’d updated (started off as libre-elec then kep applying the tar updates, rather than doing a clean flash). I have just re-flashed to a new sd card (so I have access to all the old logs, etc) and the issue is still there.
Kodi crashes (and then reloads) whenever I try to use the search functions within Placenta/Incursion. The first symptom of this was in 8.90.1 when I could perform a “new search” but it wouldn’t return any results if I selected a search string that was in the list of prior searches.
Since 8.90.2, I cannot search at all. Kodi just dies
They’re both 3rd party add-ons, both forked from exodus/covenant. (I’m happy to close/delete thread if these add-ons aren’t permitted as discussion topics though)
I’ve tried your suggestion already. In my first post you’ll see that I’ve actually performed a virgin fresh install and the problem is still there.
