Hello i have a question, i remeber in the past you can press a key and Kodi shows some data over the Stream, Audio Bitrate and some more in realtime, on the top left side. At Coreelec 9.2.2 it still give it?
greets
greets
It’s the O key.
The O key gives you information about the audio and video codecs, and how they are being decoded. It also, in CoreElec, also gives you the output format on the right. It also gives you CPU stats. This is rendered using standard skin techniques.
CTRL+SHIFT+O gives you more detailed information about A/V bitrates, dropped and skipped frames etc. This is overlaid in a simple way to avoid the overlay itself causing frame drops/skips etc.
