There are no slowdowns after 2h of constant playback, but… A lot of files is played only for 1-2 seconds, then you can hear audio for 10 sec., than video plays with high freamrate to keep sync with audio and then black screen. So return back to 9.01
Does your update keep original DTB? Because wifi speed is incredibly low.
You had before running 9.0.1? If not get the 9.0.1 release running and afterwards upgrade with the test version. There is a also help thread for the 9.0.1 release.
I head 9.0.1 before. Refreshed repos and it works again. Anyway from my point of view smth is wrong with this test release. Like I wrote before live tv is not working like described and a lot of other files don’t play.
Sorry for the late reply Previously I’ve messed something up with addon version, but now i definitely use your version with default settings (same as here), and unfortunately i still have slowdowns twice an hour with IPTV
sorry to join the party a bit tardy.
my problem is, that while my ambilight ( adalight with adruino on a c2 with libreelec and hyperion addon) works when for example i play music and the visualisation is turned on, it does not while playing a movie or watching tv. My guess is that there is a problem with the grabber - where could i start to narrow the problem down and can i even fix it? Sorry a bit new to all of this.
Thank you
