/$ udevadm info /sys/bus/sdio/devices/sdio* | paste
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0 0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0 0 1179 0 0 0 0 0 0 --:–:-- 0:00:01 --:–:-- 0100 1197 100 18 100 1179 7 518 0:00:02 0:00:02 --:–:-- 525
http://ix.HTTP/1.1
Not sure what that is, but it’s the not URL I asked for.
The paste command returns a simple url, none of the output you posted.
what about this: http://ix.HTTP/1.1
nope, should look something like this:
CoreELEC-GTK:~ # udevadm info /sys/bus/sdio/devices/sdio* | paste
http://ix.io/1Wb4
am using WinSCP. PuTTY, give me format for “host name”
I don’t really know what you’re doing. PuTTY is just like a standard terminal. You type in the command and press enter.
what am doing i have never done it. so i need help
Right. So when you start putty, you type in the ip address of your box and press open.
user: root
pass: coreelec
Then you get a terminal with a command prompt. Simply copy paste the command I posted and press Enter (right click pastes in putty). To copy text from putty, simply highlight it.
Also for k2 Pro with update 9.2.0, Bluetooth is not working.
Older versions worked without problems.
udevadm info /sys/bus/sdio/devices/sdio* | paste < Returned:
http://ix.io/1Wbn
For my box (Mecool KM9 PRO, S905X2 2G/16G) this is the output:
http://ix.io/1Wc8
fyi, bluetooth was working with the nightly/develop version of the end of august, but with the 9.2.0 release, not anymore.
Right. We’ll look into it. Adam has made some adjustments to the way BT FW is loaded, perhaps it caused a problem with some devices. He’s currently on vacation, I’m sure we’ll get this sorted when he’s back and has time to look into this.
CoreELEC
https://coreelec.org
CoreELEC (official): 9.2.0 (Amlogic.arm)
CoreELEC:~ # udevadm info /sys/bus/sdio/devices/sdio* | paste
http://ix.HTTP/1.1CoreELEC:~ #
Not sure what’s up with that. Try it without the | paste and then just copy-paste the output.
CoreELEC
P: /devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH=/devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: DRIVER=bcmsdh_sdmmc
E: SDIO_CLASS=00
E: SDIO_ID=02D0:4335
E: MODALIAS=sdio:c00v02D0d4335
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=20654819
E: SYSTEMD_WANTS=brcmfmac_sdio-firmware-aml.service
E: TAGS=:systemd:
Please, give a link to the latest stable before 9.2. Nightly is not working too. Thank you
I hope this isn’t a serious request, look one post up.
What with that? I dont understand. Still does not work. Please a link for 9.0.3 update.
MeCool KIII Pro:
CoreELEC (official): nightly_20190919 (Amlogic.arm)
L: 0
E: SDIO_CLASS=00
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=35697281
E: TAGS=:systemd:
P: /devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:2
L: 0
E: DEVPATH=/devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:2
E: SDIO_CLASS=00
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=35697411
E: TAGS=:systemd:
P: /devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:3
L: 0
E: DEVPATH=/devices/d0070000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:3
E: SDIO_CLASS=02
E: MODALIAS=sdio:c02v02D0d4335
E: SUBSYSTEM=sdio
E: USEC_INITIALIZED=35696738
E: TAGS=:systemd:
ok, found it here
just reinstalled both TVheadend and all OK
pls, have you found a solution?
