I want to install Kodi on my Odroid N2 and that’s the reason why I have chosen Coreelec. Unfortunately I don’t know where to start. In the install guide, it’s recommended to use Rufus to install the Coreelec image, but it doesn’t exist for Linux. Can you recommend me an alternative ? For me, if I can install it from the commandline it’s also not a problem, I just don’t know how.
On my eMMC I use an adaptater and I deleted the whole content of the eMMC card. After that, I can create different partitions, but I don’t know how many and which type of filesystem. When I will know those information, would a command like the following be enough ?
dd bs=4M if=CoreELEC-Amlogic-ng.arm-9.0.3-Odroid_N2.img.gz of=/dev/sda stat us=progress oflag=sync
Thank you, it’s what I used. I didn’t create any partition on my eMMC card. I deleted the whole content of the card, downloaded the image for Coreelec and then uncompress it. Then with
