bgx
31 August 2019 17:32
#1
I try to connect a sd1306 oled to my odroid c2 but I can’t connect. Is aml_i2c on in odroid c2 build?
And the output of
CoreELEC:~ # i2cdetect -y -a 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: 00 01 02 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: – -- – -- – -- – -- 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: – -- – -- – -- – -- – -- – -- – -- – --
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77 78 79 7a 7b 7c 7d 7e 7f
seems a bit strange…
It seems very weird.
If no i2c-1 then your command results an error message not this.
You should double check your wiring, especially sda, scl.
bgx
31 August 2019 22:22
#3
Wiring is correct. I read somewhere in the odroid c2 forum that this output seems normal for c2 but it should work thought. But I can’t get something on the display.
Here I ask for help but we didn’t found a solution:
Great, is there a way to use it on odroid c2?
Do you have anything else to connect to the I2C bus?
Any sensor, io, memory or other display to narrow down the problem?
And the oled is working for sure?
bgx
31 August 2019 22:33
#5
It’s totaly new but it’s my first time I play with such things. I had ordered 3 displays. I can test another one…
bgx
31 August 2019 22:44
#6
Huh, feeling so bad… It’s working… 2 pins wasn’t compleatly plugged in… My bad Sorry
Double check is not a bad thing afterall…
