Hello
Someone has the remote.conf of X2 CUBE Amlogic S905X2?
Hello
Just made a working config.
0x18 KEY_POWER
0x19 KEY_MUTE
0x57 KEY_PLAYPAUSE
0x14 KEY_VOLUMEUP
0x10 KEY_VOLUMEDOWN
0x04 KEY_MENU
0x17 KEY_CONTEXT_MENU # mouse
0x06 KEY_HOME
0x40 KEY_BACK
0x46 KEY_UP
0x15 KEY_RIGHT
0x16 KEY_DOWN
0x47 KEY_LEFT
0x55 KEY_ENTER
0x54 KEY_1
0x48 KEY_2
0x07 KEY_3
0x50 KEY_4
0x12 KEY_5
0x11 KEY_6
0x4c KEY_7
0x0e KEY_8
0x0d KEY_9
0x0c KEY_0
0x5b KEY_CONFIG
0x1f KEY_BACKSPACE
Now you need to create your configuration, an example can be seen here . Don’t delete 1st line, only name and protocol could be modified in it. A list of functions can be found here .
When you have created your map file it needs to be saved in the following location.
/storage/.config/rc_keymaps/YOURMAPNAME
You must also create the following file /storage/.config/rc_maps.cfg
with the following contents.
meson-ir * YOURMAPNAME
