If I install CoreELEC on a 8 GB microSD card, everything works fine.
If I install CoreELEC on a 120 GB SSD or 32 GB microSD, everything works fine (SFTP, Samba, Kodi, tvheadend server, …) except the SSH command console, it is impossible to access it using PuTTY (after entering the right password the SSH server no longer responds). Error: ‘packet_write_wait: Connection to 192.168.xxx.xxx port 22: Broken pipe’.
Does anyone have any explanation for this strange behavior?
