Suddenly finding one of my box keeps rebooting to safe mode.
I’m struggling to see what is actually causing this from the logs attached.
Does anyone have any ideas? Was working perfectly this morning until turning the TV on this afternoon.
Cheers
Cheers
first thing I would try is fresh install to different usb
As stated, this is always the first thing you should try before posting.
Fixed it, not too sure which was the exact issue but I deleted the EPG databases and also removed the db from the actual tvheadend server and rebooted so it would create a new one.
I also found a Media file which hadn’t extracted correctly into a folder Kodi monitors so removed that and after rebooting the box all appeared to be OK.
