Running latest stable CoreELEC from microSD card (since I can not install it to eMMC due to old firmware I believe). Video played from HDD or pendrive, doesn’t matter, it stops after 5-10 minutes, CoreELEC freezes and restarts (but not always).
What coulb be the problem?
Now it’s running Android 6. Any way to upgrade firmware?
Due to being unable to install to eMMC, I tried flashing “Aidan’s ROM”, which is Google TV 9. And it worked, however I was unable to boot into CoreELEC after that with the toothpick method. Had to flash back the original ROM
EDIT: I was able to flash Android TV 9 and install CE to eMMC
Enable USB debugging on Android TV
On a PC connect to it with adb connect ip-address-of-device:5555
adb reboot update
Install with ceemmc -x
Now it’s time for testing.
Could it be a problem that CE was installed on the microSD with Android 6 firmware, then Android was upgraded to Android TV 9, and the same CE was put on eMMC?
If anyone has the same problem, the proper ROM that works well with T95N aka Mini M8S is: 3.+[v8]+Aidan's+ROM+[S905X]+[ATV+9]+(RTL+QCA9377++LTM8830).img
After flashing this ROM and installing CE to eMMC,it looks stable for now. I was able to play a 45min video, before the new ROM it froze after 5-10 minutes.
