Suspend, CEC and IR remote bugs
i observed few bugs.
  1. Suspend works(after editing sleep.conf.d) but I cannot wake up device with CEC on Panasonic Viera only with IR remote. If I try power up with CEC, box cannot be waked up even with IR remote. Works in libreelec, android, libreelec from balbes150 if I remember correctly.
    2.After suspending IR remote stops working. I tried debug over ssh but after suspend connection is refused with messenge “Network error: Software caused connection abort”. Also webserver is unreachable. But TVH client works.
  2. Suspending/turning off doesn’t work over CEC(turning off TV doesn’t shut down box). Also works in libreelec, android, libreelec from balbes150 if I remember correctly.
  3. After every wake up from suspend kodi shows menu with power options. Same as on Balbes150 release. In libreelec suspend never worked for me.
On other hand playback is butter smooth. Best FW for s905x yet for me.
Attaching logs generated after boot, up/down keys with CEC/IR remote, suspend, wake up, up/down first with CEC than with IR, back with CEC remote and reboot.
Device: Nexbox A5 1g/16g, dtb p212_1g, Nexbox uboot.
dmesg.log (142.7 KB)
kodi.old.log (223.3 KB)
