Switch audio and subtitle stream from the OSD under full‑menu mode
@matthane Could I ask if you could implement support for switching different audio tracks and subtitles from the OSD during navigation‑based playback? Right now these options are only available in the full menu. Thank you.
I can’t guarantee it, but I can add it to my list to investigate. I don’t really use menu playback myself so it’s not something I’m too familiar with yet. But sure, I can investigate.
As you have shown If you press enter (ok) during play or with vid paused you can see an option to do that there with the default skin. I find this easy to do.
I also mapped a couple of buttons to do this for language and next subtitle etc in kodi key mapper addon. I use the coloured buttons on my remote.
Thanks for the reply. You are referring to fast‑and‑slow switching. Kodi seems to support switching under IG‑type menus(edit: IG‑type menus don’t work either), but it definitely cannot do so for BD‑J type menus. Currently only R10 is capable of this.
Here is a test build for you to try: 421.03 MB file on MEGA
I believe it fixes the issue you encountered for both BD-J and IG menus. Menu playback is currently not perfect and there are other issues, but hopefully this fixes the ability to change audio stream from Kodi OSD. Please let me know. Thanks!
It keeps giving me such big surprises that my heart can barely keep up! I consider this a 100% success. I have tested 40 UHD titles. Only one title could not be tested for audio‑track and subtitle switching, due to its non‑functional menu. The test list is attached. This is absolutely fantastic. Many big thanks to @matthane and the CoreELEC team.
checklist.txt (2.8 KB)
Thanks for testing all of that! I’ve opened the PR now to incorporate the fix into the nightly builds.
I have tested another 24 UHD titles. Again, only one title cannot perform stream switching due to menu‑related issues, so the success rate remains 100%.
I also noticed washed‑out colours on menu graphics when menus are active. This appears to happen because the graphics are not mapped to BT.2020. This is a minor observation and not critical. Thanks to everyone.
checklist2.txt (1.6 KB)
Thanks for the further checks. Menu playback does need a lot of improvements, but it becomes a rabbit hole very quickly. Fixing one issue leads to finding 5 other issues. But, I think there would be an opportunity to overhaul it in collaboration with some community members, potentially. But it would be a big project. So for now, just small patches.
I understand. I am not asking for the menus to be fixed, and I do not actually use them myself. I only test them occasionally.
The two photos below show the difference between mapped and unmapped states. They are for reference only; no fix is required.
I do have some menu playback fixes in the pipeline that fix the blackscreens and some other jankiness. I should be able to submit that work soon. I am also looking at the colors, but it seems there is no “right” way to do it because it depends on how the graphics were authored, somewhat similar to PGS.
