When the device is up running with CE, won’t the /dev/dtb contains CE dtb and not Android dtb?
Hello Iziku .
Can you send me the vfd config file that is working with your T95z plus ?
Thank you in advance
hello friend have you solved the problem with the T95z Plus housing diode.
As you solved you can send me a solution thank you very much
I’m interested in this issue too.
I see Portisch suggested more than one year ago to test a custom u-boot, but I don’t get if anyone actually tried it.
I wonder if it still could be a correct way to proceed.
