I’ve tried to install CE on Tanix TX5 Pro S905X by using a sd card.
The box just gets stuck on the Amlogic logo and refuses to proceed.
After multiple tries I gave up and went with an USB - the box has installed CE on the first try and now boots up from the USB key as it should.
But I still can’t make it to boot from a sd card.
Any experience?
I would zero fill the sd card. I use http://www.lowlevelformat.info/zero-filling.aspx
then either try re-writing the image using rufus or balenaetcher
or I would clone the usb to sd using clonezilla (I frequently clone another usb/sd using this)
Thank you bubblegum57!!!
As per advice I zero-filled the sd card via the low level format app in your link.
Then re-wrote the image with rufus - done!
The box now boots up from the sd card slot.
Greatly appreciate your help!
Windows users can use diskparts clean command to achieve same. Just FYI.
