Hi all,
I know CEC is a issue with almost all Amlogic boards, but it has been fixed with a new u-boot.
I found this site:
But not sure which config file i should be using, anybody know?
Thanks in advance.
Hi all,
I found this site:
Thanks in advance.
Messing with the bootloader is highly ill advised, if you don’t know what your doing then it is best left very well alone unless you want a paper weight.
I would trade the TX92 in for a newer (S905X2/S922X) device as you can use inject_bl301 then to modify the bootloader safely.
