Tanix X4 / S905X4
BT working here with an old BT USB dongle I found.
CoreELEC:~ # dmesg
[26895.830409@3] usb 1-1: new full-speed USB device number 5 using xhci-hcd
[26895.982004@3] usb 1-1: New USB device found, idVendor=0c10, idProduct=0000, bcdDevice=15.00
[26895.982027@3] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[26895.982034@3] usb 1-1: Product: SiW
[26895.982040@3] usb 1-1: Manufacturer: SiW
[26895.982047@3] usb 1-1: SerialNumber: 1B3A05F61100
[26896.136776@3] Bluetooth: rfcomm_init_ttys: RFCOMM TTY layer initialized
[26896.136881@3] Bluetooth: rfcomm_init_sockets: RFCOMM socket layer initialized
[26896.136986@3] Bluetooth: rfcomm_init: RFCOMM ver 1.11
[26905.052701@0] input: MAXTEK AUDIO (AVRCP) as /devices/virtual/input/input12
Listening as I write on Maxtek Headphones.
EDIT: I found 4 different BT adapters and two worked and two did not.
One - a Broadcom - reported as unsupported.
Thanks for the feedback. I’ve used 3 different USB Bluetooth dongles and none of them work.
CoreELEC:~ # dmesg | paste
http://ix.io/4K1a
Unsupported device
Not sure if is supported at all.
Okay thank you.
I can confirm that this fix gets the SPDIF working on the X4 - just applied it to a new unit.
Can anyone advise if this change has gone into the dtb for the 21 release?
