Thanks for reply, Sorry, I was a little disconnected from Coreelec.
Are you referring to this compilation?
https://relkai.coreelec.org/?dir=Amlogic-no/ce-22
The Odroid C5 looks good. But its low power approach may be limiting. Do you think Hardkernel will do an āN5ā?
so if Iām reading this right, the N2+ is supported by the new Amlogic-no branch?
yes CE-NO supports the N2+
can vouch for n2+ , so a nice device for kodi-coreelec - just wished the playback of .iso or backup_folder of dvd would function as flawlwessly as on libreelec or kodi for the matter.
the C5 is snappy biit, but playback is still a bit hit and miss, sometime it function well, sometime there are artifaccts. audio on n2+ definitely quite nicer. thanks for the work , apprecited.
