My AVR is old and does not have HDMI input.
The problem was solved!
I changed the number of channels from 7.1 to 2.0
Dolby Digital enable
Dolby Digital transcoding enable
DTS enable
Dolby TrueHD disable
DTS-HD disable
and everything works well.
All Dolby-TrueHD sounds turn to Dolby 5.1.
And also all DTS-HD sounds turn to DTS 5.1.
You could also try tomorrow nightly build with old settings as it will be available.
It has some audio fixes that could be related.
