After having some problems on 8.90.3 and 8.90.4 I decided to revert to 8.90.2. Only problem is that I had no backup (that’ll teach me!). So I decided to do a fresh install and setup using 8.90.2, turning off auto-update as soon as possible and installing Tvheadend Server 4.2 which was fine. All went well until I tried to install the Tvheadend HTSP Client which gave an error: The dependency on Kodi binary instance pvr version 5.10.1 could not be satisfied.
I suppose it’s because the repository has moved on? Is there any way to get the versions that were in existence when 8.90.2 was released?
