#0 _pthread_cleanup_push_defer (buffer=0xe5399094, routine=0xf7448e10 <__funlockfile>, arg=0xe53995f8) at cleanup_defer_compat.c:28
#1 0xf537c928 in _IO_vfscanf_internal (s=s@entry=0xe53995f8, format=format@entry=0xa41aed "%x", argptr=..., argptr@entry=..., errp=errp@entry=0x0) at vfscanf.c:372
#2 0xf538d8b8 in _IO_vsscanf (string=0xc6440cc4 "20", format=0xa41aed "%x", format@entry=0x6 <error: Cannot access memory at address 0x6>, args=..., args@entry=...) at iovsscanf.c:41
#3 0xf538735c in __sscanf (s=<optimized out>, format=0xa41aed "%x") at sscanf.c:32
#4 0x004ec6f0 in CURL::Decode(std::string const&) ()
#5 0x006849a0 in CUrlOptions::AddOptions(std::string const&) ()
#6 0x004ec8e4 in CURL::SetProtocolOptions(std::string const&) ()
#7 0x0050c9a4 in CURL::Parse(std::string const&) ()
#8 0x008eb524 in ?? ()
#9 0x006da8e8 in CScraperUrl::Get(CScraperUrl::SUrlEntry const&, std::string&, XFILE::CCurlFile&, std::string const&) ()
#10 0x00552018 in ADDON::CScraper::InternalRun(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
---Type <return> to continue, or q <return> to quit---
#11 0x005653fc in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#12 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#13 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#14 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#15 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#16 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#17 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#18 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#19 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#20 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#21 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#22 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#23 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#24 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#25 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#26 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#27 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#28 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#29 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#30 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#31 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#32 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#33 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#34 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#35 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#36 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#37 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#38 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#39 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#40 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#41 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#42 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#43 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#44 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#45 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#46 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#47 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#48 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#49 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#50 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#51 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#52 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#53 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#54 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#55 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#56 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#57 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#58 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#59 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#60 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#61 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#62 0x0056610c in ADDON::CScraper::RunNoThrow(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
#63 0x00565644 in ADDON::CScraper::Run(std::string const&, CScraperUrl const&, XFILE::CCurlFile&, std::vector<std::string, std::allocator<std::string> > const*) ()
Confirmed, looks like poor coding with recursion…
