Here you are:
service.tvheadend42-9.0.117X.zip
A bug has been found by vpeter in tvh and a patch submitted to tvh to correct this problem.
I have tried a test build including the patch and the DVB-T bouquet worked without problems.
A BIG thank you @vpeter.
Hopefully this will ensure corrected tvh releases in the future.
that would be great!
Many thanks to you and vpeter.
Please can anyone reupload? Thanks.
With mentioned patch.
Amlogic: service.tvheadend42-9.2.120.zip
Amlogic-ng: service.tvheadend42-9.2.120-ng.zip
thank you so much. Which version for KI Pro?
Amlogic version.
OK but NG or non NG?
Now I have Build: 4.2.7-44 ~ CoreELEC Tvh-addon v9.1.118 (2019-03-02T05:37:40+0000) [Toggle details](javascript:void(0))
My problems is that only some of DVB-S channels from URL (enigma bouquet) are mapped. Not all.
This fix is for DVB-T channels only. I donāt know anything about DVB-S issues.
Addon is only for Amlogic and Amlogic-ng
http://micik.cz/userbouquet.bef000.tv only some channels from this URL are mapped. Not all. They never gave me answer on TVH forum so I thought this could be a solution
Worth a try at least.
Can you show the service from bouquet which is not mapped?
This zip is addon autoinstall?
Do the problematic DVB-S channels map manually without problem?
And settings will be lost?
Yes, manualy it runs. I try to tell you which channels are not mapped but now I canĀ“t download and open the file from link as IĀ“m not on my computer My browser just doesntĀ“t download nor shows this file and I canĀ“t find editor which is able to open URL
