yeh, that seems to work for both 127.0.0.1 and localhost. I’ve learnt a lot the last couple of days. thanks
Glad, you solved it.
You could remove the two “kodi” entries with 127.0.0.1/32 and 192.168.0.0/24, because the entry with 0.0.0.0/0 covers these accesses, too.
If you want to restrict the access to 127.0.0.1/32 and 192.168.0.0/24 only, you should remove the entry with 0.0.0.0/0, of course.
I’m thinking of just sticking with 192.168.0.0/24 only. Its easier to remember.
